Message 1 of 7
Scanning Hub3
Each time I run a scan on my Hub 3 via the app it always says it has to do more technical stuff.
Is this normal as I can run test 3 or 4 times in succession and it still does it. Surely once the technical stuff has been done it should be fine.
Tags (1)
  • 12.22K
  • 947
  • 1.57K
Message 2 of 7
Re: Scanning Hub3
Are you having problems with the Hub 3 ?
If so, what are those problems ?
Mike Robinson
  • 25.12K
  • 1.44K
  • 3.2K
Message 3 of 7
Re: Scanning Hub3
Ignore it. The app is in no way intelligent.
Message 4 of 7
Re: Scanning Hub3
My download speed is poor should be 100mb but past few days averages 50mb.
All checks say working fine.
  • 25.12K
  • 1.44K
  • 3.2K
Message 5 of 7
Re: Scanning Hub3
Over wifi?
You need to speedtest when wired
Message 6 of 7
Re: Scanning Hub3
Yes over wi fi
  • 25.12K
  • 1.44K
  • 3.2K
Message 7 of 7
Re: Scanning Hub3
Wifi speeds are not guaranteed.
