  • 20
Message 1 of 7
SUPER HUB 3 ISSUES
Anyone else get this?
Drives me mental and may explain all the wifi issues since installation
  • 13.25K
  • 525
  • 1.22K
Message 2 of 7
Re: SUPER HUB 3 ISSUES
If you want wireless that just works get your own router with 1Gb ports and put the hub in modem mode.
  • 1.52K
  • 83
  • 194
Message 3 of 7
Hi VIRTUAL-ALAN, thanks for your post.
If the Connect app fails to detect your Hub, here’s some things to check. Make sure that:
- You’re connected to your Hub 3’s WiFi network when the app tries to link to it. The app won’t be able to detect your Hub if you’re on mobile data, connected to one of our WiFi hotspots or to a different WiFi network.
- You’re connected to your Hub 3’s WiFi directly and not through non-Virgin Media networking kit such as Boosters, Powerlines, or different WiFi Access Points.
- You’re not connected to your Hub 3’s WiFi guest network. If you have set up a guest network, make sure you are connected to your main network when the app tries to detect your Hub.
- Your Hub 3 isn’t in modem mode. Your Hub is set to router mode by default, but can be changed to modem mode to connect non-Virgin Media networking kit. However, the app won’t be able to detect your Hub in modem mode.
- You’re not using a Virtual Private Network (VPN). If you are using a VPN service, you may have to disconnect from VPN to allow the app to detect your Hub.
Please let us know if any of that helps or not.
Tom
  • 20
Message 4 of 7
I have the HUB3 hard wired and am trying to connect to is using the virgin app and when i scan the bottom of it to get ttthe bar code etc it says "we cant find a hub.
i dont what difference it would make being on mobile data or wifi and i haved tried both and with same results
Also how can i checkif in modem mode? i do think it is not though/
I am notr using a vpn
this is all so very tiring and or £130+ a month
so something must be wrong.
  • 20
Message 5 of 7
Thanks but surely virgin should provide products fit for purpose?
  • 6.77K
  • 525
  • 1.13K
Legend
Message 6 of 7
“i dont what difference it would make being on mobile data or wifi and i haved tried both and with same results”
You cannot use mobile data to connect to the Hub3. You must use the VM SSID for the Hub3, do not connect through powerline or WiFi extenders. Does not work in modem mode with your own router.
  • 20
Message 7 of 7
Virgin told me to use the app to check abpout my hub to see how it is performing but when i do that as poer their instructions it doesnt see the hub even when i scan the bottom of the hub3 as the app says
i am trying to get my hub3 to be more stable as is forever dropping out
So still no wiser 😞
