SH5 2.4/5GHz issue
ozsat
Superstar
So we have a SH5 and two pods - so modem set to optimization which you have to have with pods.
Heres the issue:  Usually, but not always some devices (mainly Amazon Firestics) opt to pick a slow 2.4GHz connection from the SH5/pods rather than the 5/6GHz option which when connected gives nearly 400Mbps.
Is there anyway to change to different SSIDs on the SH5 - or anyway to kill the 2.4GHz signal?
1.2Gb/100Mb in Oxford (area 31) using SH5
4 REPLIES 4
ozsat
Superstar
I'm playing with the "Wireless Security" settings - it implies it does what I want.
AFAIK, the Pods and Hub only work with the factory default settings.  It's up to the "Intelligent Wifi" to sort out the devices......   If you want more granular control, you will need to get your own wifi access points.
Legend
Different SSIDs / 2.4Ghz disabled is not permitted with the VM Pods.
However retail Wireless Repeaters like an RE550 or similar do accept a split or shared SSID on the input side and will allow splitting of the SSIDs on the repeated output.
ozsat
Superstar
Thanks both - I have my own Router too - but not Wifi6.
Was hoping I could force the SH5 bands rather than just hoping they kick in.
