Vertigo_uk1
  • 8
Message 1 of 12
SH3 wifi connection ok but no internet. Ethernet intermittent
Hi all
having an issue with my broadband. SH3
it started a couple of days ago when I couldn’t connect to wifi. But could connect to Ethernet and had internet via eth. Then I could connect to wifi but couldn’t connect to 192.168.0.1 but could on Ethernet. Then I lost internet on eth and wifi but could still connect to 192.168.0.1 on eth. This has been random with different parts working randomly. Sometimes I have wifi with internet sometimes without. Majority of the time I have internet over eth
 have tried factory resetting the router. The wifi worked for 2 mins then dropped. I have tried changing my wifi channels to channels with no other users.  I have also turned off wifi optimisation and split the 2/5g said with different names. Once I did this wifi worked for about 10 mins to the point of me changing the networks on all my devices then it dropped. Sky q is bouncing between connected to router and internet to only router to nothing.  i have tried removing the 3db attenuator and this helped slightly for a short while but put my power around db then started cutting out again. so attenuator is back inline.
there are no recorded faults in my area. The network test on 192.168.0.1 doesn’t find anything wrong and vm support couldn’t find an issue and told me to monitor for 48 hours.  Apart from going and buying a new router and putting the sh3 into modem mode I’m at a loss. there was numerous t3 timeouts before i split the ssid however these aren't in the log following a restart and now i just have rcs partial service and no ranging response received.
Any help or suggestions will be greatly appreciated.
Vertigo_uk1
  • 8
Message 2 of 12
Re: SH3 wifi connection ok but no internet. Ethernet intermittent
Channels - VM5945544
2.4ghz
5.5ghz
Vertigo_uk1
  • 8
Message 3 of 12
BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/bbdd91c42beb7e8770a4d9026e0e75fe316478a6
331000000
Locked
Ranged Upstream Channel (Hz)
46200007
Locked
Provisioning State
Online
13310000006.540256 qam25
2203000000640256 qam9
32110000006.140256 qam10
42190000006.340256 qam11
5227000000640256 qam12
6235000000640256 qam13
72430000005.940256 qam14
82510000005.840256 qam15
92590000005.940256 qam16
10267000000640256 qam17
11275000000640256 qam18
122830000006.440256 qam19
132910000006.640256 qam20
142990000006.840256 qam21
153070000006.640256 qam22
163150000006.540256 qam23
173230000006.540256 qam24
183390000006.440256 qam26
193470000006.440256 qam27
203550000006.140256 qam28
213630000005.940256 qam29
223710000005.940256 qam30
233790000005.540256 qam31
243870000005.540256 qam32
1Locked40.920
2Locked40.300
3Locked40.350
4Locked40.940
5Locked40.360
6Locked40.950
7Locked40.350
8Locked40.350
9Locked40.350
10Locked40.960
11Locked40.960
12Locked40.340
13Locked40.950
14Locked40.960
15Locked40.940
16Locked40.360
17Locked40.950
18Locked40.360
19Locked40.960
20Locked40.340
21Locked40.360
22Locked40.350
23Locked40.3120
24Locked40.900
14620000745.3512064 qam1
22579996150.3512064 qam4
33260007048.3512064 qam3
43940000045.3512064 qam2
3ATDMA0000
4ATDMA0000
Vertigo_uk1
  • 8
Message 4 of 12
01/05/2021 20:45:32noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 12:04:36Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 11:29:33noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 05:43:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 01:39:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2021 01:37:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 23:10:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:59:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:59:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:59:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:59:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:59:0criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:39:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:32:53noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:26:12Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:26:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:25:12Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:25:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/04/2021 22:25:7Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
gary_dexter
  • 30.65K
  • 1.9K
  • 4.07K
Message 5 of 12
How is it behaving today?
Vertigo_uk1
  • 8
Message 6 of 12
Still flaky and just as bad.
  • 2.93K
  • 222
  • 626
Trouble shooter
Message 7 of 12
Your Upstream power level is just on the limit of 51.  The rest look okay. The SYNC errors in the log is not so good though.
However your wifi environment is a nightmare!  You obviously have loads of competing signals and it's no wonder your wifi is flaky. It may improve if you bought your own wifi kit, perhaps Unifi Access points or similar.  Or a decent Mesh system?  I'm just guessing the Hub 3 is being swamped and it can't cope.
You have said your cabled connections are fine, so that sort of proves the issues are with the environment.
As VM do not guarantee any wifi performance, it looks like it's up to you to sort it out really.
Vertigo_uk1
  • 8
Message 8 of 12
Cheers.
strange for it to affect Ethernet intermittently though but that could be unrelated.
Yeh I have been looking for a better router. So may end up going down that route. I suspect it’s the tp link living room that a neighbour has that is interfering as it seems worse when that is visible. So they may have just got that in the past few days or so. My sh is about 6 years old so thought it could be that wearing out but some people have had them for years longer and they are ok. As I say I will see if it improves and if not will buy a new router.
have been thinking maybe the tp-link archer a7 or c7 ac1750.
  • 2.93K
  • 222
  • 626
Trouble shooter
Message 9 of 12
Personally in your crowded WiFi environment I would look at the possibility of a Mesh system with the units running a cabled backhaul. That way there will be zero WiFi interference between the satellite units and the “main” one. Or perhaps a couple of PoE Unifi Access Points. These may be a hassle to install but would be worth it IMHO.
Vertigo_uk1
  • 8
Message 10 of 12
Tbh I already have Ethernet running through the house I only need wifi in the office bedroom and living room so access points with eth backhaul shouldn’t be an issue.
thanks
