mork23
  • 15
Running new VM connection alongside existing DSL
I've decided to retain my DSL connection once my new VM connection is installed.  With my wife and I now permanently based from home and the kids doubling our needs it's useful to have a backup and I thought of dedicated the DSL connection (from Vodafone) for gaming due to the supposed more response latency connectivity.  My query is, am I going to create all sorts of issues having two lots of WIFI feeds so close to each other?  I'm looking to use a MESH WIFI for the VM connection which I don't believe you can select channels for (the whole purpose, right?) so I'm assuming if I retain my current DSL router settings the MESH should just work itself out?
Appreciate any input on this.  Any potential show stoppers or suggested actions to help.  TIA
Ernie_C
  • 18.15K
  • 1.98K
  • 4.4K
Re: Running new VM connection alongside existing DSL
You having two WiFi sources is no different than you competing with your neighbours’ WiFi.
Here’s my contention with my neighbours:
tehwolf
  • 1.58K
  • 257
  • 384
Superfast
depends how much RF interference you already have in the area..
in theory, the two networks should automatically sort themselves out so that they use different channels - but this is dependent on the quality/features of the router/mesh units you use and also on how many other networks are competing for airtime in your vicinity..
you could use something like inSSIDer to have a look at the number of networks around you, this will only give you a picture of the number of networks competing for airtime, but not the utilisation of each band - so it's just a bit of a "flinch test".
You could, ofcourse, invest in a mesh that provides dual-wan features (failover, loadbalancing) and possibly policy based routing (i.e. "all traffic from my gaming PC & ps5, send out the adsl link") but this is obviously a little more advanced and something you should check your desired router/mesh system supports.. in this scenario, you'd just have one wireless network (the mesh network) and the mesh making decisions about which gateway to use..
mork23
  • 15
Thanks for the responses.  I'm tempted to cable from the DSL router and turn off the WIFI to help.  I'm only looking at hard wiring a few devices - XBOX, PC, etc so that may help with congestion.
