  • 11
Message 1 of 13
Rubbish wifi speed and connectivity
I have 1gb service which I thought would provide me with best service,  but getting very slow and intermittent connectivity
No local issues but today getting between 1 mb and 10 mb speed
I am also paying for boosters at a cost of £3 per month which I have  never got to work despite spending a lo of time trying to get them to work. That being said if the speed and connectivity are an issue then they won't work
Any advice
  • 6.49K
  • 482
  • 851
Hero
Message 2 of 13
Re: Rubbish wifi speed and connectivity
It can be difficult diagnosing problems without some basic information.
How are you connecting Wi-Fi or ethernet cable ?
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with.
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11
Message 3 of 13
I have run a test using 192.168.0.1 access and it states that I have home network issues whatever that means??
  • 14.27K
  • 590
  • 1.37K
Message 4 of 13
Always rubbish wifi so why don't you do something about it and get your own wireless router with 1Gb ports or mesh and use the hub in modem mode if you think you can do better.
  • 11
Message 5 of 13
When I enter 192.168.0.1 it comes up asking for password and has a next button?
Do I need to do this on a windows device?
  • 6.49K
  • 482
  • 851
Hero
Message 6 of 13
Below the password box it says 'Router Status' click on that.
Mike Robinson
  • 11
Message 7 of 13
Great idea, why don't I pay out a lot more money than I already have to get a service that was promised
Appreciate any advice but hope you can appreciate where I am coming from
  • 11
Message 8 of 13
Aha the text is barely visible - thanks
  • 11
Message 9 of 13
Got it but when I hit enter no responses in text box?
  • 11
Message 10 of 13
Appreciate your help by the way
