  • 8
Message 1 of 24
Router for Gigabit Speed
Recently upgraded from the 350M package to the new 1gigabit package. I want to get a third-party router and put the hub 4.0 into modem mode. I have the hub 4.0 setup in my bedroom and have my ps4 and pc both hardwired. I want a router which helps with ping for gaming reasons and improves on the wifi signal that the hub 4.0 provides. Also I want to organise the cabling as since the router is my bedroom now my gaming setup has a-lot more cables so any tips for organising/cable management would be appreciated.
Thank you
Tags (1)
  • 24.94K
  • 1.44K
  • 3.17K
Message 2 of 24
Re: Router for Gigabit Speed
Any mid-high range ASUS or TP-Link router will be fine
  • 8
Message 3 of 24
any affordable specific models you would recommend?
  • 211
  • 24
Superfast
Message 4 of 24
Asus AX56 is a good choice.
It has a decent amount of RAM too.
Virgin 350 Hub 3, 3 x V6, 2 x Asus AX56 MESH
  • 24.94K
  • 1.44K
  • 3.17K
Message 5 of 24
Define affordable?
https://www.amazon.co.uk/ASUS-Rapture-GT-AC5300-Tri-band-Gigabit/dp/B074Z5JTLT/ref=mp_s_a_1_11?dchil...
https://www.amazon.co.uk/ASUS-GT-AC2900-Recommended-Acceleration-Forwarding/dp/B07TWGRJH5/ref=mp_s_a...
https://www.amazon.co.uk/ASUS-RT-AC86U-AiProtection-Accelerator-Aggregation/dp/B075WFL15D/ref=mp_s_a...
  • 211
  • 24
Superfast
Message 6 of 24
https://www.amazon.co.uk/dp/B081TQ91TC/ref=cm_sw_r_cp_apa_fabc_oF6SFbMX1DFEB
  • 8
Message 7 of 24
what advantages if any does the Asus ROG GT-AC2900 have over the Asus RT-AX56U. I just want to understand why it's £90 more and it's advertised for gaming purposes as well, will it provide me with better ping,and is port forwarding actually gonna improve online gaming performance.
  • 211
  • 24
Superfast
Message 8 of 24
No idea, I use the AX56 on PS4 on its fine
  • 211
  • 24
Superfast
Message 9 of 24
Also the AX56 is wifi 6 capable, so a bit of future proofing.
I can't bring myself to spend £200 on a router.
  • 8
Message 10 of 24
How is the experience with your internet since you’ve switched to using the AX56, I’ve had Virgin for a year but this my first time using a non-isp router. Is it much better than using a hub 3.0/4.0?
