johnjcb1
Message 1 of 5
Router firmware
Hello I was wondering, do 1 need to update the firmware on my virgin router or does it do it automatically. As I've reset it, but it still lags, I've updated the firmware on my netgear wifi extenders,
Tags (2)
  • 2.86K
  • 215
  • 606
Trouble shooter
Message 2 of 5
Re: Router firmware
VM do the firmware updates as and when they are needed.  No input from the end user is needed.  🙂
Graham_A
  • 16.1K
  • 2.25K
  • 6.88K
Message 3 of 5
Re: Router firmware
Firmware updates on VM hubs happen automatically.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
johnjcb1
Message 4 of 5
Re: Router firmware
thank you.
g0akc
  • 858
  • 79
  • 168
Well-informed
Message 5 of 5
Re: Router firmware
VM, like many ISPs, use TR-069 (CWMP) to manage their CPE, including roll out of firmware.
A server (ACS) will send out updates automatically.
There are various explanations and details online.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
