Just joined
Router factory reset not working Hub 3.0
Hi, I did a factory reset of the router and the router settings password does not work. So, I type in the IP address on the internet and enter the factory password and it does not work. So, I cannot get into the Hub settings at all, despite doing a reset now three times. Can you pls advise? I am v concerned about security. Thank you v much and kind regards
  • 25.12K
  • 1.44K
  • 3.2K
Re: Router factory reset not working Hub 3.0
Do a 60 second pinhole reset
