  • 7
Message 1 of 12
Router Wifi Dropping Out - Help Line Not Helpful
I've been experience frequent 5-15 minute drop-outs across multiple devices whilst one or two devices still remain working. i.e. my wife's laptop continues to have wifi but my work laptop and our phones will have no wifi. The internet is still working on at least 1 device which points towards the Hub 3 being the issue.
I called the help line - the operator jumped to it being the external line rather than the router. They claimed I was moving the devices out of the wifi range despite me saying 3 times that they are all in the same room next to the Hub 3 so wifi coverage is not the problem. They said they'd "make improvements" on the line but I'm not convinced.
Does anyone have any advice on this? I'm fairly sure it's most likely the Hub given that not all devices get kicked off the network/some still have internet. I've been with Virgin quite a while now, so is it worth pushing for a newer Hub for example?
Sorry if this appears a bit frustrated, waited quite while on hold to then not really be listened to by the person on the phone.
  • 11.57K
  • 898
  • 1.48K
Message 2 of 12
Re: Router Wifi Dropping Out - Help Line Not Helpful
Forget Wi-Fi until you can determine the WAN status.
What is your contracted speed ?
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.57K
  • 898
  • 1.48K
Message 3 of 12
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 7
Message 4 of 12
We are on M100. Nothing on Service status.
No wired ports on our laptops however speedtest over wifi sat next to Router is Ping 13ms, Download 110.32, Upload 10.05
  • 7
Message 5 of 12
You can also see the live BQM graph here (installed a few hours ago)
https://www.thinkbroadband.com/broadband/monitoring/quality/share/82373cb1729da0e02c1879935b71e0e681...
  • 11.57K
  • 898
  • 1.48K
Message 6 of 12
OK, you are getting the expected speed.
Mike Robinson
  • 11.57K
  • 898
  • 1.48K
Message 7 of 12
Can you please
Mike Robinson
  • 11.57K
  • 898
  • 1.48K
Message 8 of 12
Your >> BQM << will take a few more hours to develop properly.
At the top of the next hour can you try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
  • 7
Message 9 of 12
330750000
Locked
Ranged Upstream Channel (Hz)
32600000
Locked
Provisioning State
Online
13307500006.640256 qam25
22587500004.138256 qam16
32667500004.938256 qam17
42747500005.438256 qam18
52827500005.838256 qam19
6290750000638256 qam20
72987500006.538256 qam21
8306750000740256 qam22
93147500007.140256 qam23
103227500006.940256 qam24
113707500006.138256 qam26
12378750000638256 qam27
133867500005.940256 qam28
143947500005.438256 qam29
154027500004.638256 qam30
164107500004.538256 qam31
174187500004.838256 qam32
18426750000538256 qam33
19434750000538256 qam34
204427500005.138256 qam35
214507500005.440256 qam36
224587500005.138256 qam37
234667500004.938256 qam38
24474750000538256 qam39
post1
  • 7
Message 10 of 12
1 Locked 40.3 1 0
2 Locked 38.9 9 0
3 Locked 38.6 5 0
4 Locked 38.9 4 0
5 Locked 38.9 9 0
6 Locked 38.6 5 0
7 Locked 38.9 21 0
8 Locked 40.3 5 0
9 Locked 40.9 6 0
10 Locked 40.3 19 0
11 Locked 38.6 0 0
12 Locked 38.9 5 0
13 Locked 40.3 4 0
14 Locked 38.9 6 0
15 Locked 38.6 0 0
16 Locked 38.9 2 0
17 Locked 38.6 7 0
18 Locked 38.9 6 0
19 Locked 38.9 5 0
20 Locked 38.9 7 0
21 Locked 40.3 6 0
22 Locked 38.9 5 0
23 Locked 38.9 7 0
24 Locked 38.9 2 0
Refresh data
1 32600000 47.8 5120 64 qam 5
2 39400012 47.3 5120 64 qam 4
3 46199996 47.3 5120 64 qam 3
4 53699974 49.3 5120 64 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
4ncxv9873254k;fg87dsfd;kfoA,.
SFID 6310
Max Traffic Rate 117000047
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 6309
Max Traffic Rate 10500047
Max Traffic Burst 16320
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
