raj2021
Router Connection dropping
Hi All
Good morning , since last few weeks i am experiencing  connection dropping and all devices connected to the router lost connection for /sec/mins
and then i put a ping from my mobile and i can see its timeout and then re-connect again
I didnt tried the direct cable connection , but i am sure its some thing wrong with router to main hub
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Re: Router Connection dropping
Which router is it??
raj2021
Its says HUB3,
  • 8.45K
  • 674
  • 1.51K
You must try an Ethernet cabled connection and see if it drops at the same time. If it’s everything then it’s one set of actions, if it’s only WiFi then another.
raj2021
I will try it now
but i can see all my wifi connected devices dropping at same time, i have a booster as well that seems failing
time to replace the hub ?
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
