on 01-04-2023 15:21
Hi all,
I changed to virgin media on Thursday (hub 3) and I can't connect my ring doorbell (2nd gen)
I read about the 2.4ghz and 5ghz and I changed it but still not connecting..
Any help please? - and please explain like I'm 5 😂
on 01-04-2023 15:36
We have a Hub 3 and it is not a problem to connect on the 2.4Ghz WiFi band, we have devices doing this.
Below I will paste in a two screen shots of our Hub 3's WiFi settings, it may help you.
Hub's menu is at http://192.168.0.1/ the numeric password in on the sticker on the bottom of the Hub3
Hub's menu Advanced settings >>> Wireless >>> Security
Hub's menu Advanced settings >>> Wireless >>> Wireless signal
on 01-04-2023 18:18
Thanks for your help, unfortunately hasn't worked. I put my settings exactly as yours were. And this is the error I'm getting
on 01-04-2023 20:06
The process around step 8 talks about connection issues :
https://support.ring.com/hc/en-gb/articles/115001773266-Setting-up-your-Ring-Video-Doorbell-in-the-R...
on 01-04-2023 21:12
Thank you, I've tried but still not working 😩
on 04-04-2023 11:53
Hi Kayla1990x,
We're sorry to hear you're having an issue with connecting your Ring doorbell to your WiFi network. I can only apologise that some helpful advice from our community members also hasn't helped.
Is this the only device that is having the issue connecting? Are you getting any error message at all?
Have you tried changing the SSID and passphrase to see if this helps?
Pop back and let us know so we can help further.
Many thanks,
on 04-04-2023 22:21
It was the only device I was having an issue with but I changed the 2.4ghz channel to 6 (I read it on the forum) and my dad also gave me a spare ring chime, I did both of these at the same time and it worked, so not sure which one solved the issue, but it's fixed. Thank you 🙂
