JacobMaddox
  • 12
Message 1 of 10
Return Old Kit
I got a message on my mobile with a number to ring so I can find out when they are close to my address to pick it up. but it doesn't work what should I do.
japitts
  • 20.67K
  • 2.65K
  • 4.74K
Message 2 of 10
Re: Return Old Kit
What was the number you were asked to call?
JacobMaddox
  • 12
Message 3 of 10
Re: Return Old Kit
07860 041003
japitts
  • 20.67K
  • 2.65K
  • 4.74K
Message 4 of 10
Re: Return Old Kit
I concur that number doesn't work for me either - I presume that was the number quoted in the message. Was the message from a different number - in which case have you tried calling that number instead?
JacobMaddox
  • 12
Message 5 of 10
Re: Return Old Kit
It doesn't show a number it only says Virgin Media instead of displaying one
JacobMaddox
  • 12
Message 6 of 10
Re: Return Old Kit
Thus it's not call-able
JacobMaddox
  • 12
Message 7 of 10
Re: Return Old Kit
Do you have any advice? I could try their call centre but I do not know which options I'd have to input to get to the right department since it's so automated. I attempted to previously but none of their call options really describe the issue and I don't think getting a person to answer from the internet issues department would help much
roy247
  • 3.33K
  • 288
  • 777
Wise owl
Message 8 of 10
Re: Return Old Kit
The info on this page might help,
https://www.virginmedia.com/help/return-or-recycle-equipment
if you scroll down the page there is a form you can fill in for returning packaging,
https://www.virginmedia.com/help/virgin-media-return-or-recycle-equipment/request-returns-pack
Or you can wait for one of the forum team to pick this up which might be 2 to 3 day's.
JacobMaddox
  • 12
Message 9 of 10
Re: Return Old Kit
I'll wait a few days as I do not have the box that the new stuff came in so finding a new one will be a hassle.
Robert_P
  • 5.54K
  • 252
  • 476
Message 10 of 10
Re: Return Old Kit
Hi JacobMaddox
Thanks for posting in regards to returning your equipment, we appreciate you taking the time to raise this via the forums.
As roy247 has advised, you can check what needs returning here and order returns packaging here. Have you been able to arrange these since your post?
Rob
