Message 1 of 7
Resetting Ethernet Connected Device Name
Hi ,
I was changing a few names of the devices connected to my modem on the virgin media hib settings. I accidently changed the name of the wrong connected device by ethernet. Is there a way I can reset it to the default name?
Reason I ask is, because it was my cctv cameras that are connected to the modem and now they have gone offline. This was what I changed last and nothing else. So I assume it was possible related.
Appreciate any help
Tags (1)
  • 24.72K
  • 1.43K
  • 3.15K
Message 2 of 7
Re: Resetting Ethernet Connected Device Name
Renaming devices won’t cause them to disconnect.
Message 3 of 7
Hi thank you for this response.
is there a way to still reset the device to the default name ?
  • 24.72K
  • 1.43K
  • 3.15K
Message 4 of 7
You could try disconnecting it then reconnecting it again.
  • 2.8K
  • 160
  • 347
Message 5 of 7
Hi kala123, thanks for your post - sorry for the delayed response.
Further to gary_dexter's suggestion above - if that doesn't put the name of the cctv back to default you may need to factory-reset the hub, that will certainly do it. However all settings/passwords will revert to default and you'll need to reconnect all devices manually.
Tom
  • 14.75K
  • 620
  • 1.42K
Message 6 of 7
A bug that needs you to reset the hub...thats going to go down well...
  • 2.8K
  • 160
  • 347
Message 7 of 7
From my understanding of what's happened it's not a bug - kala123 changed the name manually and wants to revert it back to default - probably because they don't remember what the specific default device-name was - if they know what the device-name was they could rename it manually again. If not, and if disconnecting/reconnecting doesn't help, then a reset would be the only solution.
Tom
