  • 6
Replacing Hub 3 with Hub 4
I've been having issues with my wifi and my hub 3, ive finally been sent a replacement hub3 which has sorted out some of the issues with the virgin boosters.  I use to use a TP link booster, but now some of the devices closer to the router are dropping out.
I called and asked if I could have a replacement again with a Hub 4, but not too sure now I've seen all the issues on here.  Any advise ??
I have about 24 devices connected, smart plugs, security cams etc
  • 11.76K
  • 916
  • 1.51K
Re: Replacing Hub 3 with Hub 4
Look on here at the posts about the Hub 4.
IMHO, stick with the Hub 3, put it in Modem Mode and connect a decent LAN side Router or Mesh System to it.
Mike Robinson
Tags (1)
  • 24.66K
  • 1.42K
  • 3.14K
The hub4 Wi-Fi is no better than the hub3. Worse in some cases.
  • 6
Thanks for reply, I will try and stick it out with the hub 3
  • 3.62K
  • 280
  • 497
Superfast
Honestly the best thing you can do is put the HUB 3 in modem mode and get your own third party router.
  • 6
Thanks, will look on here for assistance with which is the best one to get
