Replacement hub needed
Sneakypossum
Hi. We need a replacement hub as ours is not working after some water was spilled on it. We need this asap as we work from home. Please advise.
3 REPLIES 3
If your need is urgent, you should ring Customer Services.  This is a Community based forum so will take a few days before a VM Mod picks this up for action.
fizz
Fibre optic
or on the other hand it could take days to actually get through to customer services.... but yes should be trying them first
My Broadband Ping - Virgin Modem Mode
Hi Sneakypossum
When calling Faults (option 2) 150 from a Virgin landline or mobile, or 0345 454 1111 you will hear the automated response asking you to press 1 for the link to online support etc
Ignore all the options and don't press any buttons then you should be placed into a queue and an agent should pick up the phone. It will probably require a tech visit.
Once booked keep an eye on your online account (My Virgin Media)  and check under Orders and Appointments.  It might take a few hours  to populate.  It should show your appointment and allow you to re-arrange it.
It's not likely, but if there has been a cancellation then you can try and bring the appointment forward.
Dave
The do's and don'ts.
