bdoverdrive
Replacement Hub
Evening guys
Hope you are all well,
Having several issues with my router and tonight it finally gave up the ghost.
Been trying to get through to speak to someone but cannot reach anyone,
Could someone possibly DM me to arrange a new router?
Thank you
Andrew-G
  • 6.2K
  • 1.1K
  • 2.63K
Re: Replacement Hub
In what way has is it deceased?  VM forum staff can arrange a replacement if it's bust, but the majority of connection problems are cable network configuration issues rather than a faulty hub.  If you get the hub replaced and its a network config issue, then problems will persist.
Beth_G
  • 3.15K
  • 197
  • 308
Re: Replacement Hub
Hi bdoverdrive,
Welcome to the Community Forums - it's great to have you onboard.
Sorry to hear you've been having some trouble with your hub, can you please expand on the exact issues you've been having and what state the hub is currently in? Is there no power going to it at all or are you just unable to connect?
I've not been able to find your account from your forum information, so I've popped you over a PM to take some details just in case you do still need help.
Kind regards,
Beth
