Removing Virgin Hardware and Cable
servicesmc
Settling in
What is the best contact or process for removing Virgin cable and connectors from a newly purchased property? Remedial work needs to be done on the building  therefore the kit needs to be removed. I am not a Virgin customer.
2 REPLIES 2
jpeg1
Virginmedia will not normally come and remove or change their equipment if you are not a paying customer. They would be hoping that you or a future resident might want to use it.
A pair of side cutters or secateurs will do the job.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Natalie_L
Hello servicesmc,
Welcome to the community and thank you for posting.
Our team don't usually attend to remove cables from a property once it has been installed unless a replacement is required.
Are the cables currently above ground at all?
Nat
