on 11-09-2023 00:04
I've been receiving increasingly worse performance over time with my Gig1 Fibre connection with the Hub 4. Generally speaking watching YouTube or any streaming service capable of buffering hasn't caused any issues, but gaming is very difficult because of the frequency of packet loss and huge spikes in latency for 5-10 seconds every 30 minutes to an hour causing regular disconnections.
09/09
10/09
Answered! Go to Answer
on 11-09-2023 07:27
Clues of a severe noise issue from connection stats:
1. There are over eight hundred million errors on the 3.1 Downstream channel.
2. The 3.1 Upstream channel is degraded to QAM 32 modulation mode.
You may get progress reports on this via 0800 561 0061 - it is an automated number for faults in your street.
on 11-09-2023 00:12
Router status
Item | Status | Comments |
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
Channel Overview | Downstream | Upstream |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
4 | 162750000 | 2.400002 | 43.376591 | QAM256 | 4 |
1 | 138750000 | 3.299999 | 43.376591 | QAM256 | 1 |
2 | 146750000 | 3.599998 | 43.376591 | QAM256 | 2 |
3 | 154750000 | 3.200001 | 43.376591 | QAM256 | 3 |
5 | 170750000 | 2.299999 | 43.376591 | QAM256 | 5 |
6 | 178750000 | 0.900002 | 40.366287 | QAM256 | 6 |
7 | 186750000 | 0.599998 | 40.946209 | QAM256 | 7 |
8 | 194750000 | 2.400002 | 40.946209 | QAM256 | 8 |
9 | 202750000 | 2.700001 | 43.376591 | QAM256 | 9 |
10 | 210750000 | 2.599998 | 43.376591 | QAM256 | 10 |
11 | 218750000 | 2.200001 | 43.376591 | QAM256 | 11 |
12 | 226750000 | 2.099998 | 40.946209 | QAM256 | 12 |
13 | 234750000 | 2.299999 | 40.946209 | QAM256 | 13 |
14 | 242750000 | 2.500000 | 40.946209 | QAM256 | 14 |
15 | 250750000 | 2.500000 | 40.946209 | QAM256 | 15 |
16 | 258750000 | 3.200001 | 43.376591 | QAM256 | 16 |
17 | 266750000 | 3.200001 | 43.376591 | QAM256 | 17 |
18 | 274750000 | 3.099998 | 40.366287 | QAM256 | 18 |
19 | 282750000 | 3.000000 | 40.946209 | QAM256 | 19 |
20 | 290750000 | 2.700001 | 40.946209 | QAM256 | 20 |
21 | 298750000 | 2.700001 | 43.376591 | QAM256 | 21 |
22 | 306750000 | 2.200001 | 43.376591 | QAM256 | 22 |
23 | 314750000 | 1.700001 | 40.946209 | QAM256 | 23 |
24 | 322750000 | 1.900002 | 40.946209 | QAM256 | 24 |
25 | 330750000 | 2.000000 | 40.366287 | QAM256 | 25 |
26 | 338750000 | 2.700001 | 40.946209 | QAM256 | 26 |
27 | 346750000 | 3.099998 | 43.376591 | QAM256 | 27 |
28 | 354750000 | 3.000000 | 43.376591 | QAM256 | 28 |
29 | 362750000 | 3.099998 | 40.946209 | QAM256 | 29 |
30 | 370750000 | 3.200001 | 40.946209 | QAM256 | 30 |
31 | 378750000 | 2.900002 | 40.946209 | QAM256 | 31 |
3.0 Downstream channels
4 | Locked | 43.376591 | 0 | 0 |
1 | Locked | 43.376591 | 0 | 0 |
2 | Locked | 43.376591 | 0 | 0 |
3 | Locked | 43.376591 | 0 | 0 |
5 | Locked | 43.376591 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 43.376591 | 0 | 0 |
10 | Locked | 43.376591 | 0 | 0 |
11 | Locked | 43.376591 | 0 | 0 |
12 | Locked | 40.946209 | 0 | 0 |
13 | Locked | 40.946209 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 43.376591 | 0 | 0 |
17 | Locked | 43.376591 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
21 | Locked | 43.376591 | 0 | 0 |
22 | Locked | 43.376591 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.946209 | 0 | 0 |
25 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.946209 | 0 | 0 |
27 | Locked | 43.376591 | 0 | 0 |
28 | Locked | 43.376591 | 0 | 0 |
29 | Locked | 40.946209 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.946209 | 0 | 0 |
on 11-09-2023 00:14
159 | 130 | 4K | 2511 | QAM4096 | 417 |
159 | Locked | 44 | 2.0 | 813351171 | 0 |
Upstream
1 | 30100000 | 47.520599 | 5120 KSym/sec | 64QAM | 12 |
2 | 23600000 | 46.520599 | 5120 KSym/sec | 64QAM | 13 |
3 | 36600000 | 47.520599 | 5120 KSym/sec | 64QAM | 11 |
4 | 43100000 | 47.520599 | 5120 KSym/sec | 64QAM | 10 |
5 | 49600000 | 48.020599 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
14 | 10.0 | 40.2 | 2K | QAM32 |
14 | OFDMA | 200 | 53.4 | 0 | 0 |
on 11-09-2023 00:15
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | ca69834ncxv9873254k;fg87d |
SFID | 23558 |
Max Traffic Rate | 1200000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 23557 |
Max Traffic Rate | 110000274 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
11-09-2023 00:16 - edited 11-09-2023 00:20
Sun Sep 10 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 10 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 10 | 3 | No Ranging Response received - T3 time-out;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 10 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 11; New Profile: 12.;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.1; |
Sun Sep 10 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=*;CMTS-MAC=*;CM-QOS=1.1;CM-VER=3.1; |
on 11-09-2023 07:27
on 11-09-2023 09:29
Thanks, Client62. Called up the number as you suggested and no issue/faults in the area as far as the automated responses go. Helpful information nonetheless!
on 11-09-2023 11:03
Looks like there's an issue with the BQM image for the 10/09 - re-posting for brevity.
on 13-09-2023 11:41
Hi @yaheed
Sorry to hear of the broadband issues.
I can see you've had a tech visit since posting.
I hope everything has been resolved, please do pop back if not and we can assist further.
Best wishes.
