Red light
Jlilwall
I too have the same issue. Now reset the router a number of times and disconnected all cables but still have solid red light. Any chance I could also book in someone to come have a look?
1 REPLY 1
Gareth_L
Hello Jlilwall,
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with hub3 showing a red light.
I'd like to take a look into this for you.
If you can check the Logo top right of your screen that would be great.
In the meantime can you ensure the  hub is well ventilated and away from any direct sources of heat.
Gareth_L
