Red light
murph131
Red light permanently on the hub, working but can sometimes drops
2 REPLIES 2
Pinhole reset the Hub.  I'm assuming it's a Hub 3?  If the red LED persists, the Hub will need replaced.  That is the overheat warning, and if's it's faulty, it is a possible fire risk.
A VM Mod should pick this up in a day or two to discuss with you.
Lee_R
Hi @murph131 thanks for posting and welcome to our community.
Sorry to hear of your constant red light issue and for any concerns this may be causing. I would like to take a closer look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
