Red light probs
Mucks63
Have had the red light on the router now for the past 3 months, which is hot to touch. My wife's laptop though only a year old cannot connect to the WiFi. So it's a case of rebooting/resetting the hub, eventually the laptop will connect. Just done a reset laptop connected. Turned it off, now it won't connect. So there is either a problem with the router or the laptop,any ideas.
3 REPLIES 3
Suggest you leave the hub turned off. A VM staff member will be in touch.
Travis_M
Hi @Muck63
Thanks for your post and so sorry to her about this issue with your hub
I m going to drop you a private message now to collect some more information so we can get this sorted for you. Keep an eye on your inbox for a message from myself.
Travis_M
Hi Tudor,
Thank you for the reply glad to say I am back up and running VM was in touch, the same day and booked the engineer, who turned up and was brilliant she condemned the router, sorted me out, and it's ran like a dream ever since.
Mucks
