Red light on virgin media hub
Shack2
Same issue as the rest on here. Red light on Hub 3 for months. Have unplugged, reset and even left it off for a weeks holiday. No joy on the phone as every option sends you round in circles.
1 ACCEPTED SOLUTION
Accepted Solutions
lotharmat
Community elder
Ok- hang tight for a VM forum rep and they'll be able to book a hub replacement:
If it's a red light in Router mode as opposed to modem mode - VM need to swap out the hub asap as it is either overheating or thinks it is due to a faulty sensor!
2 REPLIES 2
lotharmat
Community elder
Sabrina_B
Hi @Shack2 👋.
Thanks for reaching out to us. Sorry to hear you are having red light issues on your Hub 😢. As @lotharmat (Thanks mate) has stated it would be a replacement as we can see you have already done what we would request of you. In order to get this done, we would need to bring you into a private message, just look for the purple envelope and my message will be in there just to ask a few questions.
Sabrina
