on 07-10-2023 17:52
My router is constantly showing a solid red light and it is also feeling hot. We have restarted it quite a few times with no success. I am afraid of it overheating.
on 07-10-2023 18:19
Is my Hub 3 hot or not ?
It can be the LED is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
on 09-10-2023 18:29
Hi @Brotherfair
I'll send you a PM now to help further with this.
Best wishes.
