VMus3r
Red light on router
The red light is continuously on!  Our router is Hub 3.0 and recently for the past week it shows a continuous red light.  The router has been sitting on the same shelf in the hallway since we joined Virgin in July.  The red light has only come on in the last week.  The wifi is patchy and slow but does still work.  Any ideas on how to get it sorted?  Apparently a red light signifies overheating but: It doesn't feel hot to the touch and the light is even on during really cold nights very early morning before any central heating in the house comes on.  Any ideas please?
Tags (1)
Zach_R
  • 4.81K
  • 156
  • 330
Re: Red light on router
Hi @VMus3r,
I'm so sorry to hear of the issues that you're facing with your connection and Hub 3. Please try the following steps for me and let me know how you get on.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Zach - Forum Team
VMus3r
Thank you Zach_R I have once again tried turning it off and on but it's still showing red.  Do you think something inside the router must be faulty because it was working fine with no red light from July and has only recently started showing red?  Thank you.
Zach_R
  • 4.81K
  • 156
  • 330
Hi @VMus3r,
Thank you for giving that a try. It's a shame to hear that it hasn't helped.
I'm going to send you a private message in a few moments. Please respond to this when you can and we'll go from there.
Zach - Forum Team
