Woko1133
Red light on router
Hi everyone,
I've had a red light on my router for a long time now and have called 3 times with this issue as the website shows that this is a over heating light.
All they tell me to do is a pin reset which never works.
I've seen the below link and they got a new hub.
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-3-0-red-light/td-p/4388223
I work from home and if this goes I will be unable to work, also if this is an overheating light and it catches fire when I'm not in.....
Any advise would be much appreciated
Tags (1)
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
Re: Red light on router
If the hub is in router mode then the red light means either the hub is overheating or it thinks it is - either way it needs replacing!
Woko1133
How do I go about this has Ive tried 3 times with no luck?
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
VM Staff should pick this up.
Or you could phone 150 - use the 'Leaving option'
Tell them that the hub feels hot and has a red light on - Even if it doesn't feel hot - it needs replacing as the sensor is faulty and you wouldn't accept a faulty brake sensor on your car!
Gareth_L
  • 6.95K
  • 424
  • 781
Hi Woko1133
Sorry to read the above and the over heating hub
I am more than happy to take a look at this for you
We will need to book an engineer to come out to swap it over
I will need to send you a private message to pass security to do this
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 6.95K
  • 424
  • 781
Hello Woko1133
Just a quick message to see how things are after the visit
Gareth_L
