Greenbean85
Message 1 of 5
Red light on router not fixable
Can anyone please help? I've rang virgin support a few times and I keep getting told everything is OK, yet I've still got a red light on my router. I have 2 WiFi pods, they don't pick up the network. I'm just not winning. I personally feel as if I just need a new router. An anyone please help?
Tags (1)
  • 13.9K
  • 1.08K
  • 2.82K
Message 2 of 5
Re: Red light on router not fixable
What hub do you have? As a red LED means different things on different hubs?
Reece_MH
  • 1.92K
  • 81
  • 173
Message 3 of 5
Hi Greenbean85,
Thanks for your post, and a warm welcome to our Community Forums.
I'm sorry to hear you're having some problems with your Wi-Fi Pods, and also seeing a Red Light on your Hub. In regard to the Pods, are you seeing any lights on either one? Can you please also try the following on your Hub:
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
This should clear the red light issue you're experiencing. Please do let us know if you continue to experience this problem and we'll do our best to help.
Reece - Forum Team
Greenbean85
Message 4 of 5
Thanks for the reply, but I've restarted it several times. Been on the phone twice and unsuccessfully got the light back to white. I think I need a new router.
Natalie_L
  • 6.6K
  • 238
  • 510
Message 5 of 5
Hi Greenbean85,
Thank you for your reply and for letting us know.
We are going to need to run a few checks which will require account access so I will pop you over a private message now.
This will be available via the purple envelope on the top right of this page.
Speak soon,
Nat
