Red light on hub
cedric
I have had a different colour light for a while in the lounge and problems with a 2nd box dropping recordings in the back room. Today I now have a red light on the hub and Internet and recordings are dropping off. I have reset the box to no avail.
Can an engineer be arranged through here?
5 REPLIES 5
If it is a Hub 3 and the red led stays on after a power cycle it should be replaced as that is a faulty overheat warning.
If you wait here a day or two a VM Mod will pick this up and discuss with you.
What hub model is it?
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
Nathan_B
Hi there @cedric 👋 Welcome back to the forum and thanks for your post 😊
Sorry to see that your having issues with this Hub. Just to confirm, is the Hub overheating at all. Can you please try the following:
• Then use the power switch to turn the unit back on. The Hub should now operate normally
If you continue to see the same issue on the Hub, please let us know and we will arrange an engineer to replace this.
Nathan
cedric
Thanks Nathan. There is no overheating but I did as you said and still have the red light. I have checked all connections and rebooted many times to no avail.if you could sort an engineer after the Xmas period.
Colin
Hi @cedric 👋.
Thanks for the update. We need to bring you into a private message to get this arranged for you.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
