on 04-01-2024 10:26
I’ve had a red light on my hub for weeks. Funnily there is nowhere in “help” to advise about this. I’ve done a speed check and it says it’s fine (it’s not fine).
Online chat isn’t working and can’t call as working.
I’ve done all the usual resets etc that I found on other posts here.
on 04-01-2024 10:55
If you have done a pinhole reset, and it's a Hub 3, then it will need swapped out. The red LED is an overheat warning and should be working, otherwise it is a potential risk. If you wait here a day or two a VM Mod will pick this up and discuss with your directly.
on 04-01-2024 13:27
Hi Carolineastro,
Thank you for your post and welcome to the community.
I'm sorry to hear about the red light on the hub.
We would need to replace the hub. I will private message you now to confirm your details.
^Martin
