Red light on hub after new installation
Ash327
Just set up my hub 3 via quick set up (self installation) connecting to internet seems to be fine however hub was showing a orange light but now turnt red.
I’ve tried turning off from mains, pin reset but still red?
Is this common for new start up and will it solve itself to a white light shortly?
1 REPLY 1
Ryan_N
Hi Ash327,
Thank you for your post and welcome to the forums!
If what you have advised is the case and after the reboots and resets it is still the same - I am going to pop you over a private message so I can take a look into this for you.
Cheers,
Ryan.
