19-07-2021 11:44 - edited 19-07-2021 11:55
I have had a red light on my hub 3 for over 2 weeks now.It is not overheating and has been on a floating shelf since it was first installed.Last week my iPhone kept dropping WiFi,not sure if it was a fault with the iPhone or hub.While on the phone to virgin the automated call said there was a problem and they had to restart my hub to resolve it but after restarting it’s still showing a red light.
Answered! Go to Answer
22-07-2021 16:33 - edited 22-07-2021 16:34
Virgin engineer replaced my hub 3 earlier today,as lotharmat had said hub thought it was overheating and needed replacing.Thanks to everyone for their help.
on 19-07-2021 11:50
on 19-07-2021 11:57
It is in router mode,how do I get a replacement then as I always end up with a bot and they don’t seem to understand.
on 19-07-2021 12:31
on 19-07-2021 12:40
Thanks for your advice,I will wait and see then.
on 21-07-2021 12:01
Hi @billy149uk
Thanks for posting on our community forum!
I'm going to private message you now to collect a few more details, please keep an eye on your inbox.
on 02-08-2021 18:58
Hello,
I have similar issue with my router, is just constantly showing just red light. Connection is dropping, WIFI seems to be disable, only connection m
by cable works sometimes.
on 02-08-2021 19:39
Hi @pretorek,
Welcome to our Community Forums and thanks for posting.
I am sorry to hear this. A red light on the hub usually indicates it is overheating.
Can you confirm if you are in router or modem mode?
Is the hub hot to touch? If so, we would advise turning off the router to let it cool down and ensure it is out in the open and well ventilated.
May also be worth carrying out a factory reset. If the red light indicator is still on after this, let us know and we will arrange for a technician to come out and get this replaced for you.
Cheers
on 02-08-2021 20:17
Hello, router isn't hot, red light shows all the time, even after few hours of being off. It is in router mode. I have it 5 years staying in the same place and never experienced problem like that. Factory reset obviously didn't change a thing
