@TheGazelle77 wrote:
Thanks. What I find strange then is if that's modem mode set up, I had the Etherlet cable connected between router and mesh but no connection. Really stupid question but should i be connecting the cable into any specific port on the hub?
depends on the hub - if it's a 2/2ac then it's the one closest to the power socket on the hub. if it's the 3 or 4 then i think any port will do. There is a specific order you need to follow to get modem mode up and running though..
Log into the hub on http://192.168.0.1 and select the option to put the hub into modem mode
The hub will then reboot and come back up in modem mode - give it five minutes to settle down
Disconnect all ethernet cables from the hub
Power off the Hub and your router/mesh system
Connect your router/mesh system to the hub via ethernet cable and switch it on - leave it five minutes to settle down
Power on the hub and leave it five minutes to settle down
Should all be working.
