Red light on gub
Frhowty
Have followed all the advice on here to reset the hub 3 but still have the red light which suggests I need a new hub . Customer services are non existent and as  I work from home part time leaves me asking what I do next .
Really unimpressed with virgin and its lack of customer service
1 REPLY 1
Zach_R
Hi @Frhowty,
I'm so sorry to hear that you're experiencing issues with your connection along with a constant red light on your Hub 3. If you haven't done so already, please follow these steps.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains after following the above then please respond to the private message I'll be sending to you shortly and we can proceed from there.
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
