ok, let's clarify a couple of things
1) is it a hub3?
2) do you have the hub on modem mode?
if the answer is yes to both of those then there is no issues, as the light should be magenta (but more often red).
if it isn't in modem mode then a red light means overheating.
call CS and report the issue if that is the case.
