Message 1 of 7
Red light Wifi Issues
I've have a constant red light on the router (hub 3)
I have done a full factory reset (multiple times) - Reconnected all cables
My Wi-Fi is still working but drops out and the signal strength is v poor, it used to cover my house but doesn't any longer
I have to wire my laptop into the router to be able to do my work as signal dropping out is a major issue in the job I do, meaning I cant use my office.
I have tried to ring Virgin 3 times but every time after about an hour of being on hold they just cut me off without getting through to any one.
I guess all I need is a new router sending out and maybe a signal booster for my office.
I have logged an official complaint and I am still waiting for someone to contact me.
I had though Virgin was a premium service but the customer support is basically none existent, calling it poor would be a massive understatement.
  • 15.21K
  • 1.2K
  • 3.57K
Message 2 of 7
Re: Red light Wifi Issues
registered a compliant - with respect give them chance
a red light usually means the hub3 is over heating - will still work as you have found but needs replacing - if its not boxed in its just faulty - i would not leave it on at night or if you are not in the house - unlikely to be a problem bet better safe than sorry
will flag the thread to get VM here to organise a replacement
____________________
Tony
Message 3 of 7
Thanks for the reply.
I have spent three hours on hold just getting cut off before I logged the complaint! So I thought I’d given them a chance.
  • 1.34K
  • 71
  • 135
Message 4 of 7
Good morning @crantockjude
Welcome to the forums and thank you for taking the time to post.
I have reviewed what you have advised, we are defiantly going to need to send you out a replacement hub 3.
I have taken this opportunity to order this for you, It should be with you in the next 3-5 days,
I would also be more than happy to order a WiFi booster if needed however please note that there is an additional £3 a month charge for these.
Kind regards,
Zak_M
Message 5 of 7
Thank you. I’ll wait and see how new hub performs before deciding on a booster.
  • 1.34K
  • 71
  • 135
Message 6 of 7
No problem at all,
If you need us to order the boosters then please do let us know.
Kind regards,
Zak_M
Message 7 of 7
I have the new router up and running and the wifi is much more stable now. Thank you.
I have downloaded the connect app and checked my service around the house. I do have a bit of a black spot in the office where the WiFi is signal very weak.
I read that if you are a telephone, wifi and broadband customer you should be able to get a booster for free, does my account not qualify for this as I do take all three?
I do not want to pay an extra £3 per month for a booster and would rather purchase an off the shelf one with a one off cost if I do not qualify to get the Virgin one for free.
Could you check this for me and if not is there any off the shelf boosters you would recommend?
