on 21-12-2022 16:32
I’ve been having issues with a red light in my box for weeks. Done all the usual checks-resetting, checking wires etc.
do I need a new hub?
on 21-12-2022 16:36
Hi @Shell1278
Thank you for your post and welcome to our community.
I am sorry to hear that.
The red light indicates that either the router is overheating, or there's an issue with the connection to the LED.
Could I please confirm you have done the following?
• Then use the power switch to turn the unit back on.
If you have, the red light is still on, then yes you will need a replacement.
We can assist with that here for you.
Please pop back to us when you can.
Vikki - Forum Team
on 21-12-2022 16:38
Yes I have tried all that you stated and still the same
on 21-12-2022 16:39
Okay thank you.
I will send you a private message now so we can arrange the new hub.
Please look out for the purple envelope in the top right of the page and pop me a reply when you can.
Vikki - Forum Team
on 21-12-2022 20:01
Hi Shell1278, I am picking this up on behalf of my colleague.
Before I book a tech visit, please can you confirm you've also tried a pinhole reset of your hub, as per here? Please only try, if you're still able to clearly see your original WiFi password.
Lee_R
on 21-12-2022 21:08
Yea I have also tried that
on 22-12-2022 11:54
Thanks for coming back to us Shell1278, I would be happy to take a further look into this for you but would need to confirm a few details via private message, please look out for my message and we can get started.
Kind Regards,
Steven_L
on 22-12-2022 12:48
I have arranged a technician appointment for you, this appointment can be tracked. Please sign into My Virgin Media and you will see your appointments on your account dashboard. However, this can take up to 24 hours to be updated.
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for.
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Kind Regards,
Steven_L
