Hello Mousedeer4,
Thanks for your first post and welcome to our Community.
Sorry to hear you are having an issue with the red light on your hub
I'd like to take a look into this for you as we will need to swap this.
In the meantime can you please ensure the following.
The hub is in a well ventilated place and away from any direct source of heat.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
