Jamesmum
Red Light permanently on
Hi, three days ago the red light came on permanently. We have tried shutting the hub down and doing the factory reset nothing worked. Never had a red light before - looked it up and it says it is the overheating light, nothing has changed around our hub and it does not feel hot to touch. Rang customer service who say it is the modem working and it's fine. Having never had the light before despite having the router for years I find that explanation difficult to believe. Any ideas what I should do next? Thanks in advance.
  • 16.31K
  • 712
  • 1.6K
Re: Red Light permanently on
Likely a bug with the firmware if your connection is fine.
Ashleigh_C
  • 1.03K
  • 45
  • 89
Hi there @Jamesmum
Thank you so much for your first post to our community forums and welcome on board, it's great to have you here.
I'm so sorry to hear this is happening with your Hub! Having looked at your account I can see there are a few issues with your equipment, for this reason I think it would be best to have an engineer out to look at your set up directly.
I'm going to send you a PM to arrange this, please keep an eye out for the purple envelope in the top right corner alerting you to a new message.
Thank you.
Ash_C
