on 19-10-2023 11:11
I also have the red light on my HUB 3. I did few restarts and pin hole reset. Nothing has changed. Any advice? Thanks
on 19-10-2023 12:46
Hi SzilF 👋 Welcome to the community! Thank you for posting.
Sorry to hear about this issue with a constant red light on your Hub 3. We would need to send you a PM to confirm a few account details so we can look into this further, and arrange a technicians appointment if needed.
I will do this for you now - you can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
