Red Light on Hub 3.0
johnread1201
My hub has been displaying a red light for over a month and I’m experiencing intermittent connection problems
It’s located in a well ventilated area and is not hot to touch but depite rebooting and doing a pin hole reset several times, the problem persists.
Does the hub need replacing?
1 ACCEPTED SOLUTION
Accepted Solutions
Legend
Hub 3 RED Hot or not ?
It can be the LED is fading or it can an over temperature fault.
To check login in to the Hub 3 menu at http://192.168.0.1/   use the numeric Hub password from the bottom side label.   ( hint ... not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry.   Is it normal ?
7 REPLIES 7
Legend
Zach_R
Hi @johnread1201,
Thank you for your post and welcome back to our community forums. We're here to help.
I'm so sorry to hear that you're having some trouble with your Hub 3 displaying a constant red light. If you haven't done so already, please follow these steps.
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
If the issue remains after following the above, please respond to the private message that I'll be sending to you shortly and we can proceed from there with this.
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
Thanks.
I’ve run the Newtork diagnostic tool and the temperture is normal.
The results do say that the network has wifi connection problems but is doesn’t specify what they are.
Thanks Zach.
I’ve followed the above steps and the issue remains.
Legend
We see the same Hub 3 messages of poor WI-Fi signal, it is our mobiles  or Kindles or laptops that have reduced their Wi-Fi transmission power so as to remain connected at a low speed & to save on battery during extended idle periods.
Thanks for coming back to the thread @johnread1201.
We'll need to ensure that the hub is replaced in this circumstance for you - as the red light would be a symbol of potential overheating, and of course we wouldn't want any customers to be at risk of any potential health and safety risks.
Check out the envelope in the top right hand corner and I'll take some details from you to arrange the replacement.
David_Bn
Thanks for working with me over our private messaging function @johnread1201, and I'm pleased to have this resolved for you.
Do please keep us posted on how the replacement serves you, and let us know if anything further is required.
David_Bn
