on 06-08-2023 17:52
My Hub 3 remains with a solid red light even after rebooting, moving the location, leaving it off to cool overnight. Leaving me with an intermittent internet connection.
In the network logs I'm getting critical errors and warnings (T3 & T4)
I have it setup in Modem Mode with a TP Link Router.
Thanks for any help.
Mitch
on 06-08-2023 18:23
Be aware that if the hub is in modem mode the base light should be magenta.
If it is definitely red then the hub needs replacing.
on 07-08-2023 08:30
Thanks for your post on our Community Forums @Rainfizbow, and a very warm welcome to you!
Sorry to hear of the solid red light on the hub, and thanks for attempting to remedy this matter.
As per the advice from @nodrogd, this will need to be replaced.
Check out the envelope in the top right hand corner, for a private message from me.
Kindest regards,
David_Bn
