Lu3bareta
Message 1 of 10
Red LED
I got a red LED after installing Virgin media hub 3.0 in my new house, check and is showing the message internet (Fail Safe Mode) anyone can say what should I do to fix it?
  • 24.02K
  • 2.54K
  • 4.36K
Message 2 of 10
Re: Red LED
Is it actually "working"? Do you have internet connectivity? Is the base light "flashing"?
Lu3bareta
Message 3 of 10
Re: Red LED
It is working but every X min turns itself completely off again, I keep it in a good air circulated area... I believe it's something broken in the modem itself...
  • 24.02K
  • 2.54K
  • 4.36K
Message 4 of 10
Re: Red LED
I will flag for VM to come here and take a look
John_GS
  • 9.21K
  • 494
  • 832
Message 5 of 10
Re: Red LED
Hi Lu3bareta
Sorry to hear of the broadband issues. Normally the red light indicates the hub overheating, is it hot to touch?
Best,
John_GS
Lu3bareta
Message 6 of 10
Re: Red LED
Hello, thanks, its "warm" to touch, make sense the overheating because that's explain why is shutting off all the time, I just received yesterday the modem and something sound lose inside, some black plastic piece fell from it... I have a spare one (they didn't collect from the previous address) but I assume is not gonna work because they come pre-set right?
Ayisha_B
  • 1.42K
  • 50
  • 134
Message 7 of 10
Re: Red LED
Thanks for your post @Lu3bareta,
Please can you try carrying out a factory reset on the router just to see if this makes any difference to the red light? We'd also recommend keeping the hub upright, out in the open and away from any obstructions.
If you are still having the same issue, drop me a message here and I will arrange for an engineer to come out and check this over. If a replacement is required this will be swapped at the visit.
Hope to hear from you soon 🙂
Ayisha_B
Lu3bareta
Message 8 of 10
Re: Red LED
Hello, I tried the reset button many times, nothing change
Andrew-G
  • 7.03K
  • 1.22K
  • 3.07K
Message 9 of 10
Re: Red LED
Assuming you're not running the hub in modem mode (where the "magenta" LED looks red when viewed off axis), then it's a bust hub needing replacement.  A good chance the rattling is broken heat sink clips.  Overheating can occur with no external symptoms.
Ayisha_B
  • 1.42K
  • 50
  • 134
Message 10 of 10
Re: Red LED
Thanks for checking. Will pop you a PM now so we can get your address confirmed and arrange a engineer to come out 🙂
Ayisha_B
