bobprice
  • 11
Message 1 of 16
Real connectivity issues
Last night both myself and my daughter had serious issues with our Broadband. I have had a number weeks of the internet just stoping. I can connect to the wifi and have an Ethernet connection for work, but I keep getting messages saying 'no internet' on the connection, regular buffering and web streaming stopping.
I have re booted the Superhub 3, reset it to factory settings and still the issue remains.
I ahem run a port scanner on it and it shows that it regularly shuts Port 80. This should be open when I am browsing a web page. A HTTP demand should open the port for traffic to and from the web however the hub keeps it firmly closed.
I have had a succession of hubs from the original nil: Cable Modem (I was a trialist) and this is the worst one I have had. It just seems buggy and inconsistent.
I have been a Cabletel/ntl:/Virginmedia customer for over 20 years and this is the first time I have considered leaving. However I cannot keep working from home if my Teams keeps dropping out!
Any thoughts appreciated.
bobprice
  • 11
Message 2 of 16
Re: Real connectivity issues
And my stats etc:
11390000004.438256 qam1
21470000005.138256 qam2
31550000005.440256 qam3
41630000005.840256 qam4
51710000005.640256 qam5
61790000005.640256 qam6
71870000005.640256 qam7
8195000000540256 qam8
92030000005.140256 qam9
102110000004.638256 qam10
11219000000540256 qam11
122270000004.538256 qam12
132350000004.438256 qam13
142430000004.540256 qam14
152510000004.138256 qam15
162590000004.638256 qam16
172670000004.438256 qam17
182750000004.638256 qam18
192830000004.640256 qam19
202910000004.838256 qam20
212990000004.938256 qam21
223070000005.338256 qam22
233150000005.540256 qam23
24323000000640256 qam24
1Locked38.9374492813121623
2Locked38.9445357254298888
3Locked40.9410164154974441
4Locked40.3330463583218862
5Locked40.324186778419163
6Locked40.972441731350648
7Locked40.32498735214489
8Locked40.32540025019
9Locked40.31687223732
10Locked38.93591123842
11Locked40.32036223642
12Locked38.91635224243
13Locked38.91183224710
14Locked40.91108125086
15Locked38.9959026759
16Locked38.9673928920
17Locked38.9607526347
18Locked38.9401329243
19Locked40.3319326691
20Locked38.9267326663
21Locked38.9241527686
22Locked38.9255026932
23Locked40.3270325221
24Locked40.92111
26464
pstream bonded channels
14620000040.5512064 qam3
23940000038.5512064 qam4
35370000040.5512064 qam2
46030000041.5512064 qam1
1ATDMA00180
2ATDMA0050
3ATDMA00120
4ATDMA00130
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
,.iyewrkldJKDHSUBsgvca698
SFID18750
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID18749
Max Traffic Rate22000061
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
bobprice
  • 11
Message 3 of 16
And messages:
11/04/2021 08:37:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 16:31:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 16:22:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 16:20:30criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 15:02:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 14:52:23criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 13:27:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 13:26:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:48:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:48:1criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:45:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:30:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:05:35noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 12:05:35ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 11:49:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 11:49:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 11:49:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 07:41:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/04/2021 02:31:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2021 19:19:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 2.87K
  • 215
  • 610
Trouble shooter
Message 4 of 16
Power levels are within spec, however you have noise on the circuit, as shown by the huge number of PostRS errors and SYNC failures in the log.
Check all your connections from the Hub to outside and make sure they are all "finger" tight.  Other than this, you will need an engineer to locate the issue and fix it.
bobprice
  • 11
Message 5 of 16
Thanks. Yes they are.
Stupid question time. The cables to the hub are alongside a power extension lead. Would there be any issues with signals from this?
I have put the hub on top of a bookcase to try and extend the signals so there is an extension lead.
The original install was 20 plus years ago so there is a possibility the box outside or the inside box may have deteriorated. I will get an engineer call in.
Anyone know how to do this easily??
  • 2.87K
  • 215
  • 610
Trouble shooter
Message 6 of 16
The cables are shielded so should be okay.  As for the age of the cables, mine would be of similar vintage and I don't have any issues.  But best to get an engineer to check all out.  Ring VM at 08:00 as the lines get busy very quickly, or wait here for a couple of days for a VM Mod to respond.
bobprice
  • 11
Message 7 of 16
Thanks, I will give it a go, but if a Mod is about check in on me as I may have thrown the phone out of the window 🙂
Laurie_C
  • 381
  • 18
  • 40
Message 8 of 16
Hi bobprice,
Thanks for getting in touch! I'm sorry about the problems that you've been having with your connection.
I've been able to locate your account using your Forum details. I can see that there are some issues with your Hub, so I've booked an engineer appointment for you. You can find the details of this appointment on your MyVM page.
Please let me know if you have any more problems with thus.
Laurie
Laurie_C
bobprice
  • 11
Message 9 of 16
Thanks very much Laurie. They are due tomorrow. I will also ask them to check the box on the outside of the house. It was installed in Cabletel days and more than a few spiders have crawled through it since then !
Laurie_C
  • 381
  • 18
  • 40
Message 10 of 16
Sounds a bit spooky to me! Please let me know how everything goes, I'm sure our engineer will be able to sort this for you.
Laurie
Laurie_C
