Re: Whatsapp/Discord not working on WiFi
JoshField
Hi I’ve just switched to virgin Wi-Fi and have got the exact same issue and was wondering if anyone has a fix for it yet
2 REPLIES 2
Willreilly
Yes i do i have two options. First is get a vpn. Bc for whatever reason virgin media blocks whatsapp and stuff like discord. Second disable parent controls
用心棒
See if disabling Child Safe  resolves the issue; to do this sign into My Virgin Media and select  Account settings > Online security and disable Child Safe. If this resolves the issue and you need to have Child Safe active then review the categories being blocked or allow WhatsApp and Discord domains.
Have I helped? Click helpful.jpeg Mark as Helpful Answer and solved, or use thanks.jpeg Kudos to say thanks
