Re: SuperHub 3 Solid Red Light
FELLA
My Hub 3.0 has a solid red light.
Everything seems to be working correctly, including ethernet and wireless connections.
I'm in router mode and have followed all of the steps as advised.
• Turning the power switch off on the back of the Hub.
• Ensure the Hub is upright, in a well-ventilated location and out of direct sunlight, if possible.
• Switch the hub back on at the power.
I can't say for sure how long it's been like this as I rarely look and like I said everything has been working fine.
I think I may need a replacement Hub. Please advise.
0 REPLIES 0
