on 12-09-2023 12:03
Hi Sabrina
I have the same issue. Received my Hub 3 this morning and set it up, all working well. Changed it to modem mode and again no issues and fast speeds. It stopped working after a few minutes so switched it on & off again, along with the router and switch. Went through the online troubleshooting and noticed the Hub 3 was incredibly hot, even the cable. Checked online and see that it appears to be a common issue. Have left it to cool down and tried again but the red light just comes back on and I'm afraid to leave it switched on in case it's a fire risk.
Can you help me with this too please?
Answered! Go to Answer
on 14-09-2023 16:07
Hi Daniel
Thanks for the response. I've factory reset it and have left it in router mode for now and have had no red light issue since. I've been busy with work so haven't dared to try it in modem mode again. I'll have a try this weekend and see if it happens again in modem mode and if so will be in touch.
Cheers
on 12-09-2023 15:13
Login to the Hub 3 menus and run the Network diagnostic tool
Scroll down through the results looking for Temperature section - is it Normal / Over Temp ?
on 14-09-2023 15:41
Hi @Rkhorton 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the problem you're experiencing 😔
The red light indicates that either the router is overheating, or there's an issue with the connection to the LED.
In the first instance, please follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the steps the router doesn't boot back up after a few minutes, or the red light returns when it does, the router will need replacing.
Regards,
Daniel
on 14-09-2023 16:07
Hi Daniel
Cheers
on 16-09-2023 17:10
Thanks for the update @Rkhorton 😊
Please do let us know if you see any further issues with this, we're always happy to assist.
Nathan
on 13-10-2023 12:55
Sorry, I was clearly being optimistic thinking I'd have time to look at it that weekend! I've got it running in modem mode and it's working now although the LED is still red. It feels warm to the touch but if I switch it back to router mode and use the Network Diagnostic tool option to check the temperature it says it's normal. Is it just a bad LED? Thanks
on 15-10-2023 13:02
Hi @Rkhorton
Thanks for coming back to us.
Please could you do this for me;
Let me know if this fixes things with the hub red light.
Best wishes.
on 15-10-2023 16:34
Hub 3 has a White bar in Router mode and it has a Magenta bar in Modem mode.
