  • 7
Message 1 of 8
Re: Hub 3.0 and BT Whole Home WiFi
Hi Kev,
i am also on BT Whole Home and everything was working fine until about two weeks ago. Could you verify if my SH3.0 firmware has been updated or needs to be updated as well, please?
thanks,
Raoul
  • 7.43K
  • 254
  • 1.79K
Community Lead
Community Lead
Message 2 of 8
Hi @Rmcarlos
I'm sorry to hear you're having issues as well. I've had a look and your hub's firmware is still on the standard version.
What sort of problems have you been having?
Kev
  • 7
Message 3 of 8
HI Kev,
Thanks for getting back so quickly.
The internet keeps dropping out with significant frequency.  The BT Whole home mesh system remains up and the network seems stable, just no internet connection. But then it comes back online and works for about 10 minutes or so and then cuts out again.
I have the hub in Router mode and have shut off the Hub 3.0 Wi-fi to minimise interference.
The log info suggests a combination of Critical and Warning priority logs with the descriptor being permutations of: RCS partial Service; No Ranging response received - T3 Time-out; SYNC Timing Synchronisation failure - Loss of Sync.
This all started with noticeable consistency over the last two weeks I would say.
Raoul
  • 7.43K
  • 254
  • 1.79K
Community Lead
Community Lead
Message 4 of 8
Hi @Rmcarlos
Thanks for explaining the issue, that does sound frustrating and especially concerning that it's only started recently.
I've had a good look at everything on the hub and local network and I can see there have been some intermittent issues with the SNR on the cable. That just means that network conditions have made it more difficult for the signal to get through to you at full strength. This can sometimes cause drops if the signal strength drops too low.
It looks like the last significant drop was around lunchtime yesterday. From what you're describing it sounds like you might have slightly more regular drops than that. Would you mind setting up a Broadband Quality Monitor please and letting it run for around 24 hours before posting the output please? That should show us the conditions your hub is registering on a minute-by-minute basis so will help to understand if the drops match up to anything happening on the network.
I'm also going to move your post to its own thread as it doesn't look to be related to the firmware update or a general issue with the Whole Home system. If we manage to rule out everything else we can still put you forward for the update, but the firmware is designed to fix an issue where the Whole Home system would drop out intermittently, and it doesn't sound like that's happening.
Kev
  • 7
Message 5 of 8
OK - have set one up - I'll post findings same time tomorrow.
Raoul
  • 7
Message 6 of 8
HI Kev,
Here is a link to the BQM:
RMCarlos BQM
Raoul
  • 7
Message 7 of 8
Morning,
here ar ether readings for the last few days
Friday
https://www.thinkbroadband.com/broadband/monitoring/quality/share/74cbea49da7234165a6e46598a25b98363777534-24-07-2020
Saturday 25th
https://www.thinkbroadband.com/broadband/monitoring/quality/share/46af8991473221fb8e8824e2d1fedbce1a0c409d-25-07-2020
Sunday 26th:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9474bf42c30290546d261003a7ed51788baf7bee-26-07-2020
Its dropping a lot - mostly with what I would guess is significant demand in my area.
Raoul
  • 7
Message 8 of 8
Morning @Kev_B
Friday
Saturday 25th
Sunday 26th:
Raoul
