avi68
  • 61
Message 1 of 42
Random high latency and packet loss
Hi all,
I seem to be getting random high latency and packet loss. This initially happened last year just as lockdown started and then fixed itself but now Im experiencing the same issues again. Its been happening randomly for a few days but since yesterday it seems to have become worse. Now its happening multiple times a day.
The whole network slows down, wired or wireless. I start running a ping to 8.8.8.8 (from my pc connected via ethernet) and the times go up to around 500-700ms for around a minute and then go back to normal. I called when it happened last year and I was told this would happen due to the lockdown. When I called yesterday to report the same issue, I was told everything from my hub looks fine but there is clearly an issue somewhere.
I use the hub 3 in modem mode and always have. Last year I was using an asus rt-ac86u and this year I'm using a pfsense router.
I have set up a BQM graph:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e3334e68ef2cc3f7fdc2b57a6e36bc18a390408a-18-06-2021
 The times where packet loss is shown on the graph relates to the error messages in pfsense:
Jun 18 12:06:46dpinger23410WAN_DHCP 77.: Alarm latency 500727us stddev 132011us loss 15%
Jun 18 12:07:01dpinger23410WAN_DHCP 77.: Clear latency 412299us stddev 223033us loss 11%
Jun 18 11:41:03dpinger23410WAN_DHCP 77.: Alarm latency 505409us stddev 134426us loss 10%
Jun 18 11:41:19dpinger23410WAN_DHCP 77.: Clear latency 410074us stddev 231002us loss 7%
avi68
  • 61
Message 2 of 42
Re: Random high latency and packet loss
Here is the hub status:
1
323000000
-1.4
38
256 qam
24
2
203000000
0.4
37
256 qam
9
3
211000000
0.2
37
256 qam
10
4
219000000
0
37
256 qam
11
5
227000000
0
36
256 qam
12
6
235000000
-0.4
36
256 qam
13
7
243000000
-0.7
36
256 qam
14
8
251000000
-0.7
37
256 qam
15
9
259000000
-1
37
256 qam
16
10
267000000
-1
37
256 qam
17
11
275000000
-1.2
37
256 qam
18
12
283000000
-1.2
38
256 qam
19
13
291000000
-1.2
38
256 qam
20
14
299000000
-1
37
256 qam
21
15
307000000
-1
38
256 qam
22
16
315000000
-0.9
38
256 qam
23
17
331000000
-1.7
38
256 qam
25
18
339000000
-2.7
38
256 qam
26
19
347000000
-2.5
38
256 qam
27
20
355000000
-2
38
256 qam
28
21
363000000
-1.5
38
256 qam
29
22
371000000
-1.7
38
256 qam
30
23
379000000
-1.7
38
256 qam
31
24
387000000
-1.9
38
256 qam
32
1
Locked
38.9
1447
0
2
Locked
37.3
360
0
3
Locked
37.3
289
0
4
Locked
37.3
577
0
5
Locked
36.6
657
0
6
Locked
36.6
789
0
7
Locked
36.6
1059
0
8
Locked
37.3
823
0
9
Locked
37.3
825
0
10
Locked
37.6
861
0
11
Locked
37.3
1077
0
12
Locked
38.6
1014
0
13
Locked
38.6
1264
0
14
Locked
37.6
1170
0
15
Locked
38.9
1065
0
16
Locked
38.9
1144
0
17
Locked
38.9
1352
0
18
Locked
38.6
3422
0
19
Locked
38.6
2840
0
20
Locked
38.9
2031
0
21
Locked
38.9
1215
0
22
Locked
38.9
1111
0
23
Locked
38.9
1123
0
24
Locked
38.9
1715
0
1
60300081
50.8
5120
64 qam
1
2
46200015
49.8
5120
64 qam
3
3
53700073
50.3
5120
64 qam
2
4
39400108
49.5
5120
64 qam
4
1
ATDMA
0
0
0
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
1
0
4
ATDMA
0
0
1
0
avi68
  • 61
Message 3 of 42
Time
Priority
Description
15/06/2021 04:55:10
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=*.*;CMTS-MAC=*.*;CM-QOS=1.1;CM-VER=3.0;
12/06/2021 13:23:6
critical
No Ranging Response received - T3 time-out;CM-MAC=*.*;CMTS-MAC=*.*;CM-QOS=1.1;CM-VER=3.0;
11/06/2021 16:55:10
Error
11/06/2021 09:14:13
critical
08/06/2021 09:55:40
Error
01/01/1970 00:01:41
critical
Any help would be appreciated.
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Message 4 of 42
Upstream power looks a little bit on the high side but within spec! (Just!!!)
I'd try phoning in to see if there is a local issue affecting you!
The most useful and up to date info comes from the 0800 561 0061 number. Try that to see if there are any faults that the web service hasn't picked up!
avi68
  • 61
Message 5 of 42
Thanks for that. I called the number and apparently there aren't any issues in my area.
Im assuming Ill have to wait for someone to do a bit more investigation?
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Message 6 of 42
Aye - Hang tight for a VM Staffer to pick up this thread!
  • 23.79K
  • 2.52K
  • 4.31K
Message 7 of 42
It is odd in that the stats all look good - but the BQM is dreadful.
Just as a test - can you put the Hub back to router mode and disconnect your router and other ethernet connections and run it like that for a few hours - perhaps overnight? - and see what the BQM looks like over that period - N.B. as you will have a different i.p. address in router & modem modes - you will need to set up a second BQM with the new i.p. address
Can you do a check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box with no damaged cables or sheathings - no nails sticking through them, etc.
A VM person will come here in the next day or so and take a look and comment
avi68
  • 61
Message 8 of 42
Ok I can try that at night but I noticed that the BQM looked ok at night. Wouldn't it just give the same results or am I missing something?
I will also check all the coaxial cables and connections. Thanks for the advice.
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Message 9 of 42
Ooooh - That could be over utilisation issues!!
  • 23.79K
  • 2.52K
  • 4.31K
Message 10 of 42
The link you posted doesnt look ok to me at least at when I call night - midnight to 8am.
