  • 9
Message 1 of 13
Random Disconnection and Rebooting Hub 3
I've been having random network disconnection issues ever since I had my Hub 2 replaced with a new Hub 3. The Internet drops out, then the Hub reboots itself. This is happening during the day and night. Late last night/early morning around 1am the Hub disconnected and rebooted 3 times within the space of an hour.
I never had this problem with the Hub 2.
Can anyone see the issue from these Logs? Many Thanks.
1226750000-3.936256 qam12
2218750000-3.736256 qam11
3234750000-3.937256 qam13
4242750000-3.937256 qam14
5250750000-3.538256 qam15
6258750000-3.238256 qam16
7266750000-338256 qam17
8274750000-2.738256 qam18
9282750000-2.439256 qam19
10290750000-2.239256 qam20
11298750000-238256 qam21
12306750000-1.739256 qam22
13314750000-238256 qam23
14322750000-2.238256 qam24
15402750000-2.539256 qam25
16410750000-2.539256 qam26
17418750000-2.539256 qam27
18426750000-2.539256 qam28
19434750000-2.539256 qam29
20442750000-2.439256 qam30
21450750000-2.240256 qam31
22458750000-1.939256 qam32
23466750000-240256 qam33
24474750000-1.940256 qam34
  • 9
Message 2 of 13
Re: Random Disconnection and Rebooting Hub 3
Downstream bonded channels.
1Locked36.13130
2Locked36.61010
3Locked37.3340
4Locked37.6150
5Locked38.9140
6Locked38.9200
7Locked38.9130
8Locked38.9170
9Locked39.8110
10Locked39.3160
11Locked38.9270
12Locked39.8210
13Locked38.9250
14Locked38.6160
15Locked39.890
16Locked39.3130
17Locked39.8200
18Locked39.8100
19Locked39.8130
20Locked39.8140
21Locked40.3160
22Locked39.8190
23Locked40.380
24Locked40.3100
  • 9
Message 3 of 13
Upstream bonded channels.
1394000005.1512064 qam4
2537000555.1512064 qam2
3462000345.1512064 qam3
4603001805.1512064 qam1
3ATDMA0000
4ATDMA0000
  • 9
Message 4 of 13
Network Log - updated in next post
  • 9
Message 5 of 13
Time Priority Description.
04/08/2020 17:12:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 17:12:21Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 02:26:8criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 01:35:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 00:14:43criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/08/2020 00:11:3criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/08/2020 21:57:27criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 17:37:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 09:31:51criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 08:51:7Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 08:51:7Warning!Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 02:27:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 12:41:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 12:18:1criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 10:51:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 08:59:26Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/07/2020 08:59:26Warning!Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/07/2020 19:41:21criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/07/2020 20:25:32Warning!TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/07/2020 20:25:32Warning!Initializing Channel Timeout Expires - Time the CM can perform initial ranging on all upstream channels in the TCS has expired;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 2.23K
  • 164
  • 292
Dialled in
Message 6 of 13
Your upstream power levels are too high:
1 39400000 5.1 5120 64 qam 4
2 53700055 5.1 5120 64 qam 2
3 46200034 5.1 5120 64 qam 3
4 60300180 5.1 5120 64 qam 1
The above values are actually 51, however the HUB reports a decimal out!
Did your old HUB have an addtional device between the white cable at the HUB itself?
  • 9
Message 7 of 13
Hi, No it didn't
  • 2.23K
  • 164
  • 292
Dialled in
Message 8 of 13
Odd then that the power levels have changed, unless the HUB 2 was less fussy with the higher levels!
Regardless they will need adjusting by a VM engineer.
  • 9
Message 9 of 13
Thank you. I'll contact virgin and let them know.
Many thanks for your help.
  • 2.23K
  • 164
  • 292
Dialled in
Message 10 of 13
You're welcome.
