Purple light hub 3
Marie55
How do I get my hub 3 back to blue light it's purple now and I can't get internet
1 REPLY 1
Did you put the Hub into Modem mode by any chance?
Anyway follow the reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible. NOTE this will remove any custom settings you may have set in the Hub, and they will all have to be setup again.
